14 years agoThe performance question about Triple-speed ethernet
After several days hard work, I can ping my DE2-115(from terasic.com and FPAG is Cyclone IV E EP4CE115F29C7). But the performance is not good enough. The Ethernet data flow is that using 88E1111 a...
14 years agoEven if you need to process some data in hardware, I'd suggest using doing something to 'hand off' non-critical things to software - even if you write your own (not unreasonable if you only need to do UDP).
