15 years agothe Parameters of CVO with BT.656 format
HI,everybody Here is a problem about CVO.I'm trying to connect CVO with SAA7121 encoder(BT.656 PAL).But it does't work Normally,looks like Synchronization problems. The list following gives para...
15 years agoJust use the default PAL,change "Bits per pixel per color plane" to 8.Beause 4:2:2 format has 2 planes,type 3 is incorrect.
