15 years agoTG > VCO > SDI IP block issue
I have a simple test design that consist of only three IP blocks. Using Quartus 9.1, and here is the problem I can't figure out what causing it. test1: TG (720x486, 10bit sequence, interlace...
15 years agoTest1 does not work because the CVO is expecting F0=244 lines and F1=243 lines in this case. The Test Pattern Generator cannot produce this sequence. You can work around this issue as follows:
TG (720x487, 10bit sequence, PROGRESSIVE) >> Interlacer >> VCO (preset to ntsc)
