16 years agoTCP/IP 1Gbit/s - How?
Hello, is there a possibility for creating a system based on the Cyclone III which is able to transmit TCP/IP data packets with a speed of 1GBit/s? I guess that a NIOS would be to slowly f...
16 years agoIt will be extremely difficult. For UDP you could use custom hardware to handle the packets , but for TCP it is a lot harder.
If you do it by software the Nios CPU is way too slow. You'd better look for a dedicated CPU
