16 years agosystem with DDR2 HPCII can't meet timing requirement!
Hi In my project, i add a DDR2 HPCII to my system, after compilation, the timming meets my requirement. while after adding a second module to the previous system, the timing no longger meets. ...
15 years agoA pipeline bridge in front of the memory should help. I would recommend skimming through this document to learn more about where to place the bridges especially if you have hooked up a lot of masters to the memory: http://www.altera.com/literature/hb/nios2/edh_ed51007.pdf
