17 years agoStuck while building the VIP Example Design
We are trying to get the vip_example_design_3c120_v81_revc up and running on an Cyclone III EP3C120F780 Dev Kit. It is an427.pdf. I am getting stuck in the Analysis & Elaboration with the follo...
17 years agoHi wguynes
I just tried again as administrator and I still get those errors Error: Node instance "my_alt_vip_clip" instantiates undefined entity "alt_vip_clip_GNC4EQ5CK4" Error: Node instance "my_alt_vip_clip_1" instantiates undefined entity "alt_vip_clip_GNPBQZW3LV" Error: Node instance "my_alt_vip_cpr" instantiates undefined entity "alt_vip_cpr_GN2NSRR73L" Error: Node instance "my_alt_vip_crs" instantiates undefined entity "alt_vip_crs_GNWKGGJH2A" Error: Node instance "my_alt_vip_csc" instantiates undefined entity "alt_vip_csc_GNFW7UOZX6" Error: Node instance "my_alt_vip_dil" instantiates undefined entity "alt_vip_dil_GNN35ONPP5" Error: Node instance "my_alt_vip_mix" instantiates undefined entity "alt_vip_mix_GNVFXMO3FD" Error: Node instance "my_alt_vip_scl" instantiates undefined entity "alt_vip_scl_GN4UL6JZTM" Error: Node instance "my_alt_vip_tpg" instantiates undefined entity "alt_vip_tpg_GNM5FCQ7QA" Error: Node instance "my_alt_vip_vfb" instantiates undefined entity "alt_vip_vfb_GNV62V62MH" Info: Generated suppressed messages file C:/altera/81/vip_example_design_3c120_v81_revC/vip_top.map.smsg Error: Quartus II Analysis & Synthesis was unsuccessful. 10 errors, 106 warnings Error: Peak virtual memory: 332 megabytes Error: Processing ended: Tue Feb 17 14:08:48 2009 Error: Elapsed time: 00:01:00 Error: Total CPU time (on all processors): 00:00:43 Error: Quartus II Full Compilation was unsuccessful. 12 errors, 106 warnings I will try on a XP machine tonight and see if this make any difference Wiljan
