17 years agoStuck while building the VIP Example Design
We are trying to get the vip_example_design_3c120_v81_revc up and running on an Cyclone III EP3C120F780 Dev Kit. It is an427.pdf. I am getting stuck in the Analysis & Elaboration with the follo...
17 years agoI am also having the exact same problem as above.
I should note that I am using windows vista. The compiler seems unable to locate the video and image processing IP block primatives. I have been able to get the design to compile without problems on two other machines in my office, both of which are running windows XP.
