13 years ago
Stream to Memory sgdma problem
I am having two problems with the sg-dma in my system. My first issue is that the sg-dma ready signal goes low after the first element of streaming data, then returns high on the third. This causes the second element to be skipped. I am streaming data at the same rate as the sg-dma clock.
My second issue is that I can not re-use the descriptors. I try to set the hardware owned bit to 1 by the following command: DMA_desc[0].control=128;
The sg-dma ready signal goes high when I call the do_async_transfer() function, but it toggles low when it gets streaming data. No data is transferred to memory.
Can anyone help??
    we also found another problem. RAM clock was 12ps out of phase.
    Yes… I have been made my own dispacther and makes me cool.
    My dispatcher is nios less.
    - Nios only do initialization at first.
    - Nios get a ready address from dispatcher (like mutex way)
    - Dispatcher controls write master mSDGMA like round-robin (dual storage)
    TCP/IP troughput around 33Mbps
    14 bit ADC x 1024 length @ 2kHz samples
