13 years agoStream to Memory sgdma problem
I am having two problems with the sg-dma in my system. My first issue is that the sg-dma ready signal goes low after the first element of streaming data, then returns high on the third. This causes...
12 years agoI build some simple Stream to Memory in 3Mhz then forward to Stream out in 150Mhz, continuously... (DC-FIFO -> SGDMA -> Memory -> SGDMA)
But, I do some debug with "printf" command and became stuck (looks in Nios Console). When I change debug into PIO to drive LEDs, it was runs... I assumed, "printf" tho show debug process in Nios console can't follow interrupt request from SGDMA (in high speed interrupt)
