13 years agoStream to Memory sgdma problem
I am having two problems with the sg-dma in my system. My first issue is that the sg-dma ready signal goes low after the first element of streaming data, then returns high on the third. This causes...
13 years agoThat would be a better way to get the data, but this actually a test architecture for transfer to a SATA HD. I haven't purchased a SATA IP yet, but we would eventually like to store a day or two of all this sampled data on disk. Instead of the mem-to-mem sgdma, the transfer would be controlled by the SATA IP. I'm not sure if it's possible yet, but if the SATA writes are fast enough, it should work.
