13 years agoStream to Memory sgdma problem
I am having two problems with the sg-dma in my system. My first issue is that the sg-dma ready signal goes low after the first element of streaming data, then returns high on the third. This causes...
13 years agoI'm wondering if it makes more sense to stream the data directly into SDRAM and avoid having the additional on-chip RAM and DMA in your design. if you are worried about overflow then just place a ST FIFO in between the streaming source and the ST->MM SGDMA. From a programming perspective that would be a lot easier to manage since it's just a single DMA to coordinate.
