13 years agoStream to Memory sgdma problem
I am having two problems with the sg-dma in my system. My first issue is that the sg-dma ready signal goes low after the first element of streaming data, then returns high on the third. This causes...
13 years agoI have some working code that continuously takes in serial data to on-chip ram from 2 stream-to-memory sgdma's, and puts the serial data in a circular buffer in ddr memory.
The code puts the two stream-to-memory sgdma's in park mode, and the descriptor points back to itself for continuous operation. A call back is registered for the completion of each stream-to-memory descriptor to start the data transfer to the ddr3 circular buffer. The ddr3 transfer is done with a memory-to-memory sgdma with and single descriptor chain. The descriptor chain is rebuilt after each transfer. Comments are more than welcome... // CWstream1_DMA SGDMA callback function // * After each descriptor is processed (1600 bytes), the data is transfered to DDR3 memory in a circular buffer void CWstream1_callback_function(void * context) { // tx tells the circular buffer which sgdma was processed tx=0; alt_avalon_sgdma_do_async_transfer(DDR3_DMA, &DDR3_DMA_desc[0]); } // CWstream2_DMA SGDMA callback function // * After each descriptor is processed (1600 bytes), the data is transfered to DDR3 memory in a circular buffer void CWstream2_callback_function(void * context) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 1); // tx tells the circular buffer which sgdma was processed tx=1; alt_avalon_sgdma_do_async_transfer(DDR3_DMA, &DDR3_DMA_desc[0]); } // DDR3_DMA callback function // * Re-initialize the descriptor for the next memory transfer // * Check the memory position to see if the circular buffer needs to start over void DDR3_callback_function(void * context) { // update the write address of the circular buffer write_addr = write_addr + 0x640; if (write_addr >= 0x3e80) { DDR3_write_addr = DDR3_BASE; write_addr = 0; } else DDR3_write_addr = DDR3_BASE + write_addr; // Check which sgdma was processed so we can know where to read the data from if (tx == 1) { alt_avalon_sgdma_construct_mem_to_mem_desc(&DDR3_DMA_desc[0], &DDR3_DMA_desc[1], CW_DAQ1_write_addr, DDR3_write_addr, 1600, 0, 0); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 3); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 4); } else { alt_avalon_sgdma_construct_mem_to_mem_desc(&DDR3_DMA_desc[0], &DDR3_DMA_desc[1], CW_DAQ2_write_addr, DDR3_write_addr, 1600, 0, 0); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 2); } DDR3_DMA_desc[0].control=128; DDR3_DMA_desc[1].control=0; } // Main code entry // * Write a message to the LCD display for fun // * Initialize pushbutton callbacks // * Clear memory space // * Start DMA engines // * Sit in a while loop and wait for callbacks int main(void) { // Initialize circular DDR3 transfer variables write_addr = 0; // This is a software reset to the ping-pong selector hardware counter. // Pull this low and then return to the high state will reset the counter to 0. IOWR_ALTERA_AVALON_PIO_DATA(PIO_PROGRAM_BASE, 0); // Reset the sgdma controller // This is a software reset, - not sure if needed // The documentation states this is a last resort control, so we should remove this if we can. // Embedded Peripherals IP User Guide, pg 25-12 IOWR_32DIRECT(SGDMA_ST1_BASE, 16, 0x10000); IOWR_32DIRECT(SGDMA_ST2_BASE, 16, 0x10000); usleep(1000); IOWR_32DIRECT(SGDMA_ST1_BASE, 16, 0x10000); IOWR_32DIRECT(SGDMA_ST2_BASE, 16, 0x10000); usleep(1000); // Open the CW streaming scatter-gather DMA controllers CWstream_DMA1 = alt_avalon_sgdma_open("/dev/sgdma_st1"); if(CWstream_DMA1 == NULL) printf("Could not open the CW SG-DMA1\n"); CWstream_DMA2 = alt_avalon_sgdma_open("/dev/sgdma_st2"); if(CWstream_DMA2 == NULL) printf("Could not open the CW SG-DMA2\n"); // Open the Memory transfer to circular buffer scatter-gather DMA controller DDR3_DMA = alt_avalon_sgdma_open("/dev/sgdma_ddr3"); if(DDR3_DMA == NULL) printf("Could not open the DDR3 SG-DMA\n"); // Set the write addresses for data transfers CW_DAQ1_write_addr = (alt_u32 *)(DAQ1_MEM_BASE); CW_DAQ2_write_addr = (alt_u32 *)(DAQ2_MEM_BASE); DDR3_write_addr = (alt_u32 *)(DDR3_BASE); // Set up the CW stream 1 descriptor // The descriptor points back to itself for continuous operation // The PARK bit of the control register must be set in order to re-use the descriptor (done in the callback registration)r alt_avalon_sgdma_construct_stream_to_mem_desc(&CWstream_DMA1_desc[0], &CWstream_DMA1_desc[0], CW_DAQ1_write_addr, 1600, 0); // Set the OWNED_BY_HW bit to 1 on desc[0] CWstream_DMA1_desc[0].control=128; // Set up the CW stream 2 descriptor alt_avalon_sgdma_construct_stream_to_mem_desc(&CWstream_DMA2_desc[0], &CWstream_DMA2_desc[0], CW_DAQ2_write_addr, 1600, 0); CWstream_DMA2_desc[0].control=128; // Set up DDR3 1 descriptor alt_avalon_sgdma_construct_mem_to_mem_desc(&DDR3_DMA_desc[0], &DDR3_DMA_desc[1], CW_DAQ1_write_addr, DDR3_write_addr, 1600, 0, 0); // Set the OWNED_BY_HW bit to 1 on desc[0], and set the bit to 0 on desc[1] // This stops the descriptor chain at desc[1] and flags an interrupt for its callback function DDR3_DMA_desc[0].control=128; DDR3_DMA_desc[1].control=0; // Register callback functions // CWstream1 callback // The PARK_MASK allows prevent the OWNED_BY_HW bit from being cleared after the descriptor is processed alt_avalon_sgdma_register_callback(CWstream_DMA1, &CWstream1_callback_function, (ALTERA_AVALON_SGDMA_CONTROL_IE_GLOBAL_MSK | ALTERA_AVALON_SGDMA_CONTROL_PARK_MSK | ALTERA_AVALON_SGDMA_CONTROL_IE_DESC_COMPLETED_MSK | ALTERA_AVALON_SGDMA_CONTROL_IE_CHAIN_COMPLETED_MSK ), NULL); // CWstream2 callback alt_avalon_sgdma_register_callback(CWstream_DMA2, &CWstream2_callback_function, (ALTERA_AVALON_SGDMA_CONTROL_IE_GLOBAL_MSK | ALTERA_AVALON_SGDMA_CONTROL_PARK_MSK | ALTERA_AVALON_SGDMA_CONTROL_IE_DESC_COMPLETED_MSK | ALTERA_AVALON_SGDMA_CONTROL_IE_CHAIN_COMPLETED_MSK), NULL); //DDR3 callback alt_avalon_sgdma_register_callback(DDR3_DMA, &DDR3_callback_function, (ALTERA_AVALON_SGDMA_CONTROL_IE_GLOBAL_MSK | ALTERA_AVALON_SGDMA_CONTROL_IE_CHAIN_COMPLETED_MSK), NULL); usleep(1000); IOWR_ALTERA_AVALON_PIO_DATA(PIO_PROGRAM_BASE, 1); // Start the CW transfers alt_avalon_sgdma_do_async_transfer(CWstream_DMA1, &CWstream_DMA1_desc[0]); alt_avalon_sgdma_do_async_transfer(CWstream_DMA2, &CWstream_DMA2_desc[0]); // Sit in a while loop while callbacks happen while (1) { } // Should not reach this code printf("\nExit\n\n"); return 0; }
