13 years agoStratix V Transceiver Architecture
Has anyone successfully implemented 4 independent 10G Low Latency PHY transceivers with 4 separate refclks? I know it can be done with two independent PHYs by assigning one on the left and the other...
13 years agoHi m13engr,
In my case I need to implement 7 independent 10G Low Latency PHY transceivers. I got 3 independent channels and I couldn't connect any more, I also tried the two options that you mentioned. Did you find a solution? Cheers, Raquel
