15 years agostratix iv qdr_sram_compiler_wirh uniphy
hello, Now I'm using stratix iv 230 device in a project.I use qdr_sram_compiler_with_uniphy as my qdr2 chip controller.The software is quartus ii 10.0 sp1.All the docs downloaded from the web do n...
15 years agoBurst length is number of accesses per command.
Take DDR3 which is nominally BL=8 on the memory interface. If using half rate I need to provide 2 beats of data to get the entire 8 beats on the memory interface. If I do this on consecutive clock edges I can set local_size = 2 and set burstbegin high on the first one. Or if the data is not ready on consecutive clock cycles I can use local size = 1 and push the first beat in, wait and do the same again for the 2nd beat, each time setting burstbegin high.
