15 years agoStratix IV GX - QDR w/ Uniphy
I have a custom board with two x18 250MHz QDRs (GS8662D18E-250I). I am using the example project to test each QDR individually. One of the QDRs passes all the tests from the example driver while the ...
15 years agoI'm suspecting it has to do with the postamble timing. From the external memory interface handbook: Volume 4 Section III Debugging.
Postamble Timing Issues and Margin The postamble timing is set by the PHY during calibration. You can diagnose postamble issues by viewing the pnf_per_byte signal from the example driver. Postamble timing issues mean only read data is corrupted during the last beat of any read request. That is the only information that it provides on the topic. How would one make adjustments to correct this?
