15 years agoStratix IV DDR3 memory controller with Unify : simulation not working
Hello. I have a problem using DDR3 memory controller with Unify on Stratix IV. I use modelsim SE 6.5d or 10.0. My problem is that the controller is not working both with my design and Al...
13 years agoHi All,
I also had problems with the DDR3 uniPhy for stratixV. when i simulated the design with the Aldec- Active-HDL9.1 simulator i noticed that the initialization/calibration never starts. My solution for this issue was to copy the *.hex files from the "...\design_name\design_name_sim\design_name\" folder to the "..\SRC\" folder . This folder is where Active-HDL searches for hex files when they are aplicable to the design. and this worked for me!!! So, i guess you can do something similar in modelsim. I hope this helps to those of you who are still stuck. regards Dror.
