17 years agoStratix IV and DDR3
Has anyone done a Stratix IV design with DDR3? I've got a little test project set up. The DDR3 controller is instantiated inside SoPC builder. During synthesis the following error is given: E...
15 years agoHi,
I'm also doing the same thing as you did (my mem_bot_clk and mem_bot_clk_n are already in inout mode) in my top level entity but I still have the "...also drives out to other destination than the buffer" message. I also checked out the altera solution which is to convert each std_logic_vector(0 downto 0) into std_logic but it seems useless. I'm actually using Quartus II 11.0 Full Version with a Stratix IV GX 230 and I'm trying to use the Triple Speed Ethernet. My design worked fine with a Nios II until I decided to add two SGDMA (RX and TX) and the TSE core. (after that my Nios II seems to be turned off but the design still work with signaltap, I use the Nios II only for the printf() ) And my question is, does anyone know how to solve the DDR3 problem with Quartus II 11.0 ? Best regards, Michel
