15 years agoStratix IV and DDR2 - pin assignment problem?
Hello, i created a megafunction with the wizard for using the ddr2 memory on my stratix IV-board. But there seems to be a problem in the pin assignment. while place&route i get the followi...
15 years agoIn UniPHY the oct pins are called OCT_rup and OCT_rdn. This is what you need to connect your pin assignments to.
In your project they are connected to termination_blk0~_rup_pad etc. This is an AltmemPHY thing. Reassign these pins assignments to the correct pins. I would delete all assignments and rerun the <>_pin_assignments.tcl file.
