14 years agoStratix-3 DSP kit, Dual ADC usage
The Stratix-III DSP kit contains 2 ADCs, 125MSPS and controlled using seperate clocks. I was thinking if it is possible to clock the ADCs 180 degrees out of phase with each other and double the sampl...
14 years agoThanks for the quick reply Dave. It doesn't appear to have any filtering on the front end. In fact, they ship a 55MHz coaxial Minicircuits LPF to act as an external anti-aliasing filter.
I've seen the PDF you sent me, you're website has some great information and I actually had it bookmarked. Aside from that, are there any other potential pitfalls you see going down this path? Thanks Matt
