Stratix 10 Phylite IP , deviation in data sampling at different groups(Input Path Signal)
Bit [8:7] and bit [6:4] are used together to select DQ pins:
bit[8:4] = {2'h1, 3'h0} -> DQ0
bit[8:4] = {2'h1, 3'h1} -> DQ1
bit[8:4] = {2'h1, 3'h2} -> DQ2
bit[8:4] = {2'h1, 3'h3} -> DQ3
bit[8:4] = {2'h1, 3'h4} -> DQ4
bit[8:4] = {2'h1, 3'h5} -> DQ5
bit[8:4] = {2'h2, 3'h0} -> DQ6
bit[8:4] = {2'h2, 3'h1} -> DQ7
bit[8:4] = {2'h2, 3'h2} -> DQ8
bit[8:4] = {2'h2, 3'h3} -> DQ9
bit[8:4] = {2'h2, 3'h4} -> DQ10
bit[8:4] = {2'h2, 3'h5} -> DQ11
And about the abnormal behavior between groups, could you please run the simulation waveform showing the operation of all PHY Lite IP signals of both groups in one view.
So we can get the timing relationship of rdata_en, strobe_io, and rdata_valid of both groups in their testbench (and then check if there are any differences)
Could you please disable the dynamic reconfig in the IP and test again to see if the issue still happen?
regards,
Farabi
Hi Farabi,
Thanks for detailed explanation on dq pin selection.
Below is the simulation waveform on PHY Lite IP signals for both the group 0 and group 1
Group 0
Group 1
