Stratix 10 M20K Clock Clock Enable for ECC Pipeline register
Hi there,
In the M20K documentation on ECC, there is mention of an optional pipeline register within the ECC pipeline for achieving higher FMax. It is not entirely clear if adding a clock enable to the output register also adds a clock enable to this internal register.
https://www.intel.com/content/www/us/en/docs/programmable/683240/17-0/ram-and-rom-parameter-settings.html
What I want to get is a M20K block where the read addr, ECC pipeline register and output register all have a clock enable. So that reading takes 3 clock enables to complete.
Does adding a clock enable to "all output registers" add a clock enable to the internal ECC pipeline register?
Another minor question, why is it seemingly impossible to add a clock enable to the M20K output register in single-clock dual-port mode? I can only either add a clock enable to all ports, or to none of them, but in dual-clock mode this is not a problem?
One final thing, what does clock_enable_core_b: "The clock enable for the core of port B." this mean? The 'core' of port A/B?
Kind regards,
Lennart
In the end I was able to test that yes indeed, applying a clock enable to the output registers does add a clock enable to the pipeline registers as well.
As for the other questions, they're still a mystery, but at least we can continue development with this.
- SyafieqS
Hi Lennart,
Let me check this information internally and will be back with update.
- SyafieqS
Hi Lennart,
I was on long holiday thus expect some delay in update.
- LennartVH
Hi SyafieqS,
Thank you for your time. This is still an open question for us. As our build system is broken right now I can't test it myself, so having confirmation on how the M20K output registers work would really help.
Kind regards,
Lennart - LennartVH
- SyafieqS
Lennart,
Noted. Let me know if there is any other concern.
