14 years ago
Strange and random (!?) error of the Control block
Hi everyone,
sometimes it happens that I get the following errors, the problem is that they seem to appear in a random way, for example my design was working correctly but I needed to rename it and to change the directory, I did it and obviously I changed also the path of the Control block, then I tried to simulate and I got:
1.
Altera DSP Builder Advanced Internal Restriction: 'lastSlice.high <= inWidth - 1'. Error in block '.../Subsystem1/Subsystem/Mux_re' in mip_common/hw_fu.cpp:544.
2.
Error in '../Control' while executing C MEX S-function 'mip_control', (mdlStart), at time 0. MATLAB error message:
Why that?
Thanks in advance
    I'm afraid that's not really enough to go on. Ideally you need to create a design that is as small as possible that still has the problem. In most cases, you should be able to do this without giving anyway any secrets in your design.
    One pitfall I found with dspbuilder is that of model pointing to another setup m file as you move around your files.
    Try open .mdl using wordpad and check and correct the name of setup file, possibly in 3 places. save and close matlab then reopen and check again...
    That's not really a fault of DSP Builder, but of Simulink/MATLAB. DSP Builder has no control over MATLAB paths beyond its initial set up.
    I have "a kind of" solved the problem by adding In/Out wrapper of the basic blockset, I have two IP connected, if they are connected with these wrappers they work perfectly, if not (all the blocks from the advanced library) I get that error....
