15 years agoStrange and random (!?) error of the Control block
Hi everyone, sometimes it happens that I get the following errors, the problem is that they seem to appear in a random way, for example my design was working correctly but I needed to rename it...
15 years agoOne pitfall I found with dspbuilder is that of model pointing to another setup m file as you move around your files.
Try open .mdl using wordpad and check and correct the name of setup file, possibly in 3 places. save and close matlab then reopen and check again...
