15 years agoStrange and random (!?) error of the Control block
Hi everyone, sometimes it happens that I get the following errors, the problem is that they seem to appear in a random way, for example my design was working correctly but I needed to rename it...
15 years agoMmm, the problem appeared again, I was hard-coding the types then I tried to simulate the design and the error reappeared
I have attached the design with the data type, in this case only the output of the Mux is fixed, the rests are 'inhrited' Quick update: I have found that if the output of that Mux is bigger than 36bits the design does not work, is there any way to overcome this problem ? (the full design is quite small so I would prefer to not break down it)
