15 years agoStrange and random (!?) error of the Control block
Hi everyone, sometimes it happens that I get the following errors, the problem is that they seem to appear in a random way, for example my design was working correctly but I needed to rename it...
15 years ago --- Quote Start --- Could you post that picture again, but with types shown and ideally the other block that feeds the mux. You can show the types using the Format Menu. Select "Port/Signal Displays" -> "Port Data Types". If the types don't show up then, you need to refresh your model. Press Ctrl + D to do that. (and yes that's what I meant by hard-code them) --- Quote End --- Problem solved, I realized that the file of the Edit Param block was not in the right directory, after having fixed this the problem disappeared. Ok it was my fault that I didnt move the file .m , but to understand this reading that error it was not so straightforward :D
