15 years agoStrange and random (!?) error of the Control block
Hi everyone, sometimes it happens that I get the following errors, the problem is that they seem to appear in a random way, for example my design was working correctly but I needed to rename it...
15 years ago --- Quote Start --- I cant post the whole design but I posted where the error occurs, for 'hard-coded' do you mean if I defined the output type mode for each block without using the "Inherit via internal rule"? If you do, yes, I did hard-code them. --- Quote End --- Could you post that picture again, but with types shown and ideally the other block that feeds the mux. You can show the types using the Format Menu. Select "Port/Signal Displays" -> "Port Data Types". If the types don't show up then, you need to refresh your model. Press Ctrl + D to do that. (and yes that's what I meant by hard-code them)
