12 years agoStore scalar variables in DSP Adv
I used DSP Adv block to build a module which includes tens of scalar variables. I used to different dualmem blocks to store and modify them. Is there another efficient way to store? Thanks J...
12 years ago --- Quote Start --- Thank your suggestion. Unfortunately, there is not register unit in Advanced DSP builder. I tried to replace it with FIFO. This works but there are 3 delay from read. Anyway this is a smart solution instead of Dualmem which is ram and slower than FIFO. --- Quote End --- There is certainly a register block. I use it regularly and is called sample delay(find it some where under one of libraries of ADSPBuilder. It infers a register or ram depending on delay. setting it to 1 infers a register.
