15 years agostandard blockset and advanced blockset
Hi, I am doing my first design with Altera DSP Builder blocs and I want to know what bloc to use between two blocks, the fisrt is from standard blockset library and the second is from advanced blocks...
15 years agoAre you saying you want to create a system that contains both advanced blockset and standard blockset blocks?
If so then you want to look at chapter 8 of http://www.altera.com/literature/hb/dspb/hb_dspb_adv.pdf (http://www.altera.com/literature/hb/dspb/hb_dspb_adv.pdf)
