15 years agoSPI doesn't work at all
Hi, I need collect data from PIC18F4550 by SPI connection. The PIC is the Master running with Polarity = 0 and Phase = 1. The FPGA uses Altera IP SPI (3 wires Serial). All wires [SCK, MIS...
15 years agoI notice, that are writing SDO and reading SDI after SCK rising edge, which correspondends to no usual SPI mode. I don't see, which SPI mode is implemented in the FPGA, but I guess that it doesn't match the master's behaviour, which would explain well the erratic result.
P.S.: If you intend SPI mode 0, you have to set SDO before the rising clock edge.
