17 years agoSPI Core
I am using the SPI core in 7.2sp2 - I have a device (ADC128S102) which reads back data in the same 16 bit transmission as the command is sent. The chip is working fine - I can select the ADC channel ...
17 years agoI have the same problem. I want to read in an ADC (LTC2351-14). I modifiet the altera_spi_hal to my needs but i only see 8 clks when i look at the signale on a osci. I tried both, reading the reg directly and using the altera cmd.
here is the modified code: # include "alt_types.h"# include "altera_spi_regs.h"# include "altera_spi.h" int alt_avalon_command(alt_u32 base, alt_u32 slave, alt_u32 write_length, const alt_u16 * write_data, alt_u32 read_length, alt_u16 * read_data, alt_u32 flags) { const alt_u16 * write_end = write_data + write_length; alt_u16 * read_end = read_data + read_length; alt_u32 write_zeros = read_length; alt_u32 read_ignore = write_length; alt_u32 status; alt_32 credits = 1; IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(base, 1 << slave); if ((flags & ALT_AVALON_SPI_COMMAND_TOGGLE_SS_N) == 0) { IOWR_ALTERA_AVALON_SPI_CONTROL(base, ALTERA_AVALON_SPI_CONTROL_SSO_MSK); } IORD_ALTERA_AVALON_SPI_RXDATA(base); for ( ; ; ){ do{ status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0 || credits == 0) && (status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); if ((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) != 0 && credits > 0){ credits--; if (write_data < write_end) IOWR_ALTERA_AVALON_SPI_TXDATA(base, *write_data++); else if (write_zeros > 0) { write_zeros--; IOWR_ALTERA_AVALON_SPI_TXDATA(base, 0); } else credits = -1024; }; if ((status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) != 0){ alt_u32 rxdata = IORD_ALTERA_AVALON_SPI_RXDATA(base); if (read_ignore > 0) read_ignore--; else *read_data++ = (alt_u16)rxdata; credits++; if (read_ignore == 0 && read_data == read_end) break; } } do{ status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while ((status & ALTERA_AVALON_SPI_STATUS_TMT_MSK) == 0); if ((flags & ALT_AVALON_SPI_COMMAND_MERGE) == 0) IOWR_ALTERA_AVALON_SPI_CONTROL(base, 0); return read_length; }
