15 years agoSource of errors in data from SGDMA
Hello, Sorry to be back so quick but I have spent the last two days on this and am at a loss. I have an SGDMA which is reading 16 bit data from an 8bit SDRAM and streaming this to a vide...
15 years agoThere doesn't seem to be anything wrong with the memory transfers done by the DMA. You should only look at the data on the m_read interface when readdatavalid is 1. When that signal is 0 the data could be anything.
So the problem could rather come from the data written by the Nios CPU to the memory, or a problem on the memory controller when it uses bursts. Could you do a setup with a Nios CPU that has a data cache (with bursts enabled) and run a memory test application from on-chip memory? This setup should test the burst operation of the DRAM controller.
