15 years agoSource of errors in data from SGDMA
Hello, Sorry to be back so quick but I have spent the last two days on this and am at a loss. I have an SGDMA which is reading 16 bit data from an 8bit SDRAM and streaming this to a vide...
15 years agoYour signaltap image is unreadable.
I don't think that memory read or write errors in the SDRAM controller would create such a regular pattern. When you write to the SDRAM, do you flush the data cache? Do you have a FIFO between the SGDMA and the video output?
