17 years agoSOPC HP DDR2 Controller Clock Rate
I've installed a HP DDR2 Controller in the SOPC Builder. I'm curious what clock rate I can run this at. My memory can run at 400MHz CL = 3, 533MHz at CL = 4 and 667MHz at CL = 5. I'm running the c...
17 years agoYou could be absolutely correct. rogerleo has not responded as to what speed is actual memory device is. If he's got a DDR2-667 device then he will likely not get it to run at DDR2-800 speeds regardless of the FPGA.
Jake
