17 years agoSOPC HP DDR2 Controller Clock Rate
I've installed a HP DDR2 Controller in the SOPC Builder. I'm curious what clock rate I can run this at. My memory can run at 400MHz CL = 3, 533MHz at CL = 4 and 667MHz at CL = 5. I'm running the c...
17 years agoHi Jake,
I do fully understand your point. But looking at the initial post where you can find "...My memory can run at 400MHz CL = 3, 533MHz at CL = 4 and 667MHz at CL = 5...." and referring to several datasheets (Micron, Samsung) one can think the initial post adresses DDR2-400, DDR2-533 and DDR2-667 memory devices. The weird thing you can find is right at the first page of the Micron datasheet for instance for 2Gb DDR2-SDRAM devices where for DDR2-400, DDR2-533 and DDR2-667 devices the Data Rates of 400, 533 and 667 are given in MHz(!!!) and not as you did in Mbps. Samsung did a better job on their datasheet. But this just a note aside. Comming back: DDR2-400 devices are nominal driven with a 200MHz clock frequency, DDR2-533 with a 266MHz clock and DDR2-667 with a 333MHz clock. The nice thing is, that you can drive DDR2-667 devices in DDR2-400 mode by adapting clock frequency and other timings such as "CL". But with this discussion tuning clock frequency above 333MHz means either you are using a DDR2-800 device or you do overclocking your DDR2-667 device. And going back to the initial post again: Is rogerleo really using DDR2-800 or "just" DDR2-667 memory? Det
