17 years agoSOPC HP DDR2 Controller Clock Rate
I've installed a HP DDR2 Controller in the SOPC Builder. I'm curious what clock rate I can run this at. My memory can run at 400MHz CL = 3, 533MHz at CL = 4 and 667MHz at CL = 5. I'm running the c...
17 years agoIf you are using DDR on Stratix III, remember that you need to run the verify_timing tcl script to check the IO timings in addition to the normal STA in TimeQuest.
