17 years agoSOPC HP DDR2 Controller Clock Rate
I've installed a HP DDR2 Controller in the SOPC Builder. I'm curious what clock rate I can run this at. My memory can run at 400MHz CL = 3, 533MHz at CL = 4 and 667MHz at CL = 5. I'm running the c...
17 years agoMy bad. The 400MHz is for the -2 part.
I have been able to run this at 360MHz so far and it works. I did get a warning that the "Stratix III speed grade 3 does not support DDR2 SDRAM operation above 333.0MHz". But I compiled anyway and measured the clock at 360MHz. No timing errors. So I'll probably go back to 333 and stick with that.
