15 years agoSOPC error, SLAVE at two addresses
Let's see if I can paint the picture here: I have a separate clock domain behind a Avalon Clock Crossing Bridge. In this clock domain I have a slave which can be accessed by our NIOS on the ot...
15 years ago --- Quote Start --- You can force SOPC Builder to generate even though there's an error, by holding the control key and clicking generate. --- Quote End --- That's a great tip! I actually ran into the same addressing problem just a couple days ago. I changed the address of my problem bridge to zero to fix it, but I can foresee cases where that wouldn't work. --- Quote Start --- (We don't promise the results will work, though!) --- Quote End --- Do you promise my system will work when not forcing SOPC Builder to ignore the errors? :p
