11 years agoSome questions in FIFO IPcore, I use the EP4CE55F23I7
HI i have some question...In my project, I use fifo ipcore, when I use the depth of 8192,4096 or 2048, the data I read is correct, but after increasing the depth, such as 32768,65536 or bigger, the d...
11 years agoThanks for your reply.....I solved the problem by using the logiclock to lock the fifo memory. Thanks a lot
