15 years agoSome problem to integrate HDL Import block in Advanced design
Hi everyone, Im facing a nasty problem, im trying to use the HDL Import block in an Advanced design. I have followed both the instructions about how to interface Standard and Advanced blockse...
15 years ago --- Quote Start --- No if anything it should be: Simulink Input, In blocks (IO&bus), HDL Import -> HDL Input -> GPin, <datapath> , GPout -> HDL Output -> Out blocks (IO&bus) , Scope --- Quote End --- Cool, thanks!! That works perfectly!! I have just a curiosity how is Simulink able to run his functional simulation by using the HDL Import? I mean how is it able to interpret the VHDL code?
