13 years agoSoft ip core design
Hi, Basically i want to design one fifo soft ip core which should work any vendor FPGA.(I know so many fifo ip core's are there in market:-P). Already i designed fifo(256x8) using VHDL code and sa...
13 years ago --- Quote Start --- steps/process/tools involved in designing a IP core and how different it is from a RTL design. Karthi. S --- Quote End --- An IP core is just a bit of logic that someone else might want to use. I think with the Xilinx tools you can generate an encrypted netlist, in Altera land you need to become an IP partner to get your core encrypted so you can distribute it and Quartus can use it
