13 years agoSoft ip core design
Hi, Basically i want to design one fifo soft ip core which should work any vendor FPGA.(I know so many fifo ip core's are there in market:-P). Already i designed fifo(256x8) using VHDL code and sa...
13 years agoA single clock fifo should be no problem. Simple pointers and synthesizable memory is all that is needed.
However when dealing with 2 clocks, several issues come into play. You can use Gray encoding to deal with the pointer issues, but I don't think there is a safe way to synthesize a two port two clock ram. Pete
