15 years agoSNR of a Quantized Signal using FFT
Hi all, I have a problem in the calculation of SNR. Sine wave is quantized and then I have calculated its SNR using FFT. The coherence condition with windowing as well is implemented t...
15 years ago6.02*NoOfBits + 1.76 is the theoretical limit. many factors in the design and operating environment can reduce the SNR from this limit.. including improper heat dissipation, the signal source, reference voltage, poor layout, etc... check the spec sheets of the A/D and make sure you're doing your measurement/calculation properly:
see http://www.cse.psu.edu/~chip/course/analog/lecture/sfdr1.pdf
