16 years agosin waveform simulation result
I confused with the sine wave simulation result(frequency domain) between the display of NCO in IP toolbench and agilent vee simulation result(data extracted from tbl).
The spec for sin wave is: parellel cordic implementation 200k clock rate 20k sine wave 16 bit phase accumulator precision 16 bit angular resolution 24 bit magnitude precision phase modulation( 16bit modulator precision and pipeline level 1) FYI, i save simulation result as .tbl format as attached. Then i extract the data(time, fsin_o) wanted as attached based on the criteria that out_valid is high and clock transition( 0 to 1). The data(fsin_o) is feed to FFT and get the magnitude of fft and 20log magnitude of it before display. There is something wrong with the magnitude and somehow i dono what's wrong. sine wave in time domain is correct. Can someone clear my doubt? Am i extracting the wrong data? Thanks4 Replies
How can we know about your method to calculate a FFT from the data? In the shown FFT plot, both frequency and magnitude scale are mysterious. It can't be trusted anyway.
I am not particular on the frequency axis because the sine wave in time domain is correct. Besides, i have no idea to map the time and fsin_o to perform fft where i think is time consuming.
My intention is just to estimate the quality of sine wave(e.g distortion and SNR ...). I have attached the flow on how i perform fft and data extracted from tbl(simulation result). Thanks - Altera_Forum
I'm not familiar with these MatLab stuff. Generally, a 20k sine with a 200k clock should result in a fundamental at 0.1 normalized frequency and the spectrum mirrored at 0.5. I can't find it in your plot.
FvM,
I just realise that i attach the wrong fft magnitude. I am sorry abt that. I have corrected the attachment in the first post. The magnitude suppose to be in negative. However, the simulation shows that it is positive. May i know why? thanks
