17 years agoSimultaneous Write/Read to on chip dual port RAM
Obviously simultaneous writes will cause problems. In our case, one Avalon Master is reading while the other Master is writing. So, the question is, will simultaneous write and read of t...
12 years agoHi, sry for digging out this rather old thread. But I think it might be the most suitable thing to do. My problem:
I have a EP4CE55 FPGA. On there I have a DPRAM attached to a NIOS with cache. From the other side I'd fill the ram with new process dataas its coming in using a DMA. For performance reasons I'd lke to attach it as tightly-coupled memory - only supported for dual-clock mode. But then the DPRAM doesn't support the "OLD DATA" option for read-during write access. Will the tightly coupled memory increase performance significantly? In any case to access this area of data I will bypass cache (alt_remap_uncached). Is the decision really only between NEW_DATA and OLD_DATA or is it possible to really get garbage? Further on scanning the Altera Documentation a I found the following on page 3-17 of the Cyclone IV Device Handbook: --- Quote Start --- For mixed-port read-during-write operation with dual clocks, the relationship between the clocks determines the output behavior of the memory. If you use the same clock for the two clocks, the output is the old data from the address location. However, if you use different clocks, the output is unknown during the mixed-port read-during-write operation. This unknown value may be the old or new data at the address location, depending on whether the read happens before or after the write. --- Quote End --- This would imply that I can just use it in Dual Clock Mode, connect the same clock and get the OLD_DATA behaviour? Or am I getting this one wrong? Thanks!
