17 years agoSimultaneous Write/Read to on chip dual port RAM
Obviously simultaneous writes will cause problems. In our case, one Avalon Master is reading while the other Master is writing. So, the question is, will simultaneous write and read of t...
17 years agoWhen you create an altsyncram component using the megawizard, you are given the option to specify that you want the old contents to appear on a read during write operation. It's found on the output tab under the group box entitled "Mixed Port Read During Write for Single Input Clock Ram"
This option is available for M512, M4K, and M9K blocks but not for M-RAM. Of course for a dual-clock RAM, you're out of luck. Jake
