11 years agoSimulink matrix block using as input before altera blocksets but data not passing .
I am new in altera i am using Simulink matrix block as input to the altera blocksets design but data incompatibility problem arises plz someone suggest what to do?...............:):)
11 years agowhat input block are you referring to. The blocks GPin/GPout/channelin/channelout are not necessary for ADSP. You can wire simulink data directly but take care of type conversion(convert data to integers, control inputs to boolean...)
I know once a 2D array was accepted in my design but I am not sure if it was input to block or output generated by a block.
