13 years ago
Simulation Alpha Blending Mixer IP core
Hi eveyone,
i want to use Modelsim to simulation Alpha Blending Mixer. I create a control block with avalon-MM interface. But it's not working.
This is block diagram and veirilog code
//-- Project :
//-- Description : test pattern generator
//-- File : generator_ip.v
//-- Rev : 1.0
//-- Designer : Cuong.TV
//-- Date : 29 July., 2013
module generator_ip
clock,
reset,
// dout
// Avalon ST source
dout_ready,
dout_valid,
dout_startofpacket,
dout_endofpacket,
dout_data
parameter WIDTH= 192;
parameter HEIGHT=1080;
parameter N = 8; // Reg with
input clock;
input reset;
input dout_ready;
output reg dout_valid;
output reg dout_startofpacket;
output reg dout_endofpacket;
output [23:0] dout_data;
//---------------signal of edge_enhance-----------------//
wire clk_en;
wire [23:0] outedge_data;
wire wrreq;
localparam [1:0] source_reset_state =2'b00,
source_control_packet =2'b01,
source_start_data_packet =2'b10,
source_data_packet =2'b11;
reg [1:0] state_sink;
reg [1:0] state_source;
reg dout_sel;
//---Frame information---//
wire [23:0] control_array_dout [0:2];
reg [1 :0] control_count_dout; //range 0 to 3
reg [23:0] control_array_din [0:2];
reg [1 :0] control_count_din;//range 0 to 3
wire [15:0] width_std;
wire [15:0] height_std;
reg [9 :0] x_count;//range 0 to WIDTH-1
reg [8 :0] y_count;//range 0 to HEIGHT-1
//---Signal for Processing Unit---//
reg [23:0] pixel_in;
reg [23:0] control_data;
wire [23:0] pixel_data;
wire enb;
wire [2 :0] edge_const;
reg busy;
//---Odd buffer---//
reg rdreq;
//---Control register---//
reg [31:0] control_reg1;
reg [31:0] control_reg2;
assign width_std = WIDTH;
assign height_std = HEIGHT;
assign control_array_dout[0]={4'h0, width_std [7 :4], 4'h0, width_std [11: 8], 4'h0, width_std [15:12]};
assign control_array_dout[1]={4'h0, height_std[11:8], 4'h0, height_std[15:12], 4'h0, width_std [3 : 0]};
assign control_array_dout[2]={4'h0, 4'h0 , 4'h0, height_std[3 : 0], 4'h0, height_std[7 : 4]};
//------------------ generate data -------------------------//
generator u1
.clock(clock),
.reset(reset),
.rd_request(rdreq),
// dout
// Avalon ST source
.dout_data(pixel_data)
//-------------------Avalon source control FSM----------------//
always @(posedge clock, posedge reset)
begin
if (reset == 1'b1)
begin
state_source <= source_reset_state;
dout_valid <= 1'b0 ;
dout_startofpacket <= 1'b0 ;
dout_endofpacket <= 1'b0 ;
control_count_dout <= 2'b0 ;
rdreq <= 1'b0 ;
control_data <= 24'b0 ;
dout_sel <= 1'b0 ;
x_count <= 0 ;
y_count <= 0 ;
end
else
begin
dout_valid <= 1'b0;
dout_startofpacket<= 1'b0;
dout_endofpacket <= 1'b0;
rdreq <= 1'b0;
dout_sel <= 1'b0;
case (state_source)
source_reset_state: begin
x_count <= 0;
y_count <= 0;
if (dout_ready == 1'b1)
begin
dout_valid <= 1'b1;
dout_startofpacket <= 1'b1;
control_data <= 24'H00000F;
state_source <= source_control_packet;
end
end
source_control_packet: begin
begin
dout_valid <= 1'b1;
control_data <= control_array_dout[control_count_dout];
if (control_count_dout == 2'd2)
begin
control_count_dout <= 2'd0;
dout_endofpacket <= 1'b1;
state_source <= source_start_data_packet;
end
else
begin
state_source <=source_control_packet;
control_count_dout <= control_count_dout + 1;
end
end
end
source_start_data_packet: begin
begin
control_data <= 24'H000000;//indicate DATA PACKET
dout_valid <= 1'b1;
state_source <= source_data_packet;
rdreq <= 1'b1;
end
end
source_data_packet: begin
dout_sel <= 1'b1;
begin
dout_valid <= 1'b1;
if (x_count == (WIDTH -1))
begin
x_count <= 0;
if (y_count == (HEIGHT -1))
begin
end
else
begin
y_count <= y_count + 1;
rdreq <= 1'b1;
end
end
else
begin
x_count <= x_count + 1;
rdreq <= 1'b1;
end
end
end
endcase
end
end
assign pixel_data[7:0] = 0;
assign pixel_data[15:8] = 0;
assign pixel_data[23:16] = 500;
assign dout_data = dout_sel ? pixel_data : control_data;
endmodule
