TSchu3
6 years agoSimulating Triple Speed Ethernet, Decryption Fails
Hello, I am trying to simulate the TSE testbench IP generated with Quartus Prime Standard 18.0. My simulator is Cadence Xcelium. Xcelium cannot decrypt the TSE testbench submodules. I have not enco...
Deshi_Intel
6 years agoHI,
- May I know which FPGA product that you are using here ?
- Can you share with me your TSE IP QSYS design file so that I know what setting that you are using in order to duplicate this sim issue ?
- May I know which Cadence Xcelium version that you use ? Based on TSE user guide, by right there should be another ./cadence or ./xcelium sim folder that you can use
- Also, have you try with latest Quartus version like Quartus Standard v19.1 to see if it helps to resolve issue ?
dlim
