Simulating PCIE_DDR4: what are the complete setup contents.
1. Is following section 2.6 sufficient in running simulation? [Attached Screenshot]
>> Are you trying to simulate PCIe design or Emif design ?
>> if it is memery interface issue, you may refer to our official youtube channel which there got step by step guide to run the simulation
>> https://www.youtube.com/watch?v=iCr-0eOwo9o&ab_channel=IntelFPGA
2. If a separate testbench script is needed which in turn sources msim_setup.tcl. Where can I find an example of such a testbench?
>> Please refer to answer in question 1, the video shall explain how you generate the testbench for simulation
3. Is there a BFM testbench script available for reference?
Can I know which tile that you are referring for the PCIe HIP ? P-tile ? R-tile or others...
Wincent_Intel
