Simulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
- 1 year ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
# ** Error (suppressible): (vopt-14408) Intel Starter FPGA Edition recommended capacity is 5000 non-OEM instances. There are 9399 non OEM instances. Expect performance to be severely impacted.
--Please not using starter version
I typed vsim in Questa or ModelSim...
--vsim is the command to launch Questa, not the command used inside Questa
That being said, I clicked on pci_ed_tb after typing vsim as the testbench file
--do vsim at pcie_ed_tb/pcie_ed_tb/sim/mentor
Rong
